Salta al contenuto principale
Disassembling Qualcomm QCP-2760 Rear Backing
Cosa ti serve
  1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: passo 1, immagine 1 di 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: passo 2, immagine 1 di 2 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: passo 2, immagine 2 di 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
Conclusione
Xavier
Membro da: 10/02/14
313 Reputazione
3 Guide realizzate
Ohio State, Team 1-4, Buehl Fall 2014 Membro di Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 201
