Salta al contenuto principale
Introduzione
Removing the casing is necessary to replace the LCD screen or the buttons.
Parti
Nessuna parte specificata.
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Remove the batteries from the camera.
    • Remove the batteries from the camera.
  5. Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  6. Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
Conclusione
Dani
Membro da: 24/06/2010
21 Reputazione
7 Guide realizzate
Cal Poly, Team 3-3, Johann Summer 2010 Membro di Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,452
