Introduzione
This guide will show you how to separate the body into the trigger frame and the bolt frame. This will allow you to access the solenoid and eyes.
Parti
Nessuna parte richiesta.
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Aggiungi Commento
Pull the grip away from the frame.
  • Pull the grip away from the frame.
Aggiungi Commento
  • Pull the grip through the opening.
  • The grip is connected in the middle and is one piece.
Aggiungi Commento
  • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
Aggiungi Commento
  • While pulling in the metal ring on the fitting, pull the macroline out.
Aggiungi Commento
  • Use 1/8" allen wrench to remove screw behind regulator.
Aggiungi Commento
  • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
  • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
  • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
Aggiungi Commento
Conclusione
Rett Triplett
Membro da: 18/10/2013
801 Reputazione
8 Guide realizzate
Clemson, Team 13-6, Benson Fall 2013 Membro di Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 454
