Introduzione
This guide will show you how to remove the main camera lens assembly from the camera's frame.
  1. Remove the following screws:
    • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Remove the two indicated screws on the bottom of the camera:
    • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    • Carefully pull the back of casing away from the front.
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
    • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
    • Pull the cover plate off for the two power cord jacks.
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    • Remove the orange tape on top of the SD cardholder.
    • Open the battery cover and lift plastic piece off.
    • Remove tape on left side of camera.
    • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
    • Remove top left LCD bracket.
    • This is a small piece, be careful not to lose it.
    • Push down bottom left LCD bracket to release the LCD from grip.
    • Gently lift up LCD screen.
    • Slowly pull LCD screen to the left to remove it from the other grips.
    • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
    • Lift up tape slightly on both sides of speaker.
    • Use the pointed end of a spudger to lift up brackets.
    • Lift speaker cover out.
    • Remove speaker cover.
    • Turn camera to front.
    • Carefully peel off orange wire tape. The tape is glued to the surface indicated.
    • Lift speaker from holder.
    • Use a wedge to lift up the wire tape flap.
    • Insert the point of a spudger underneath the wire shown.
    • Carefully lift the wire out of the crevasses.
    • Slowly bend the speaker's wire tape away from the lens assembly. Avoid creasing the tape.
    • Remove indicated screws:
      • Three Black 3.80mm Phillips #00 screws.
    • Remove the indicated black 3.40mm Phillips #00 screw on the bottom of the camera.
    • Remove copper leads.
    • Unscrew the indicated 3.80mm Phillips #00 screw on the back of the camera.
    • Remove screw and bracket.
    • Turn the camera over to the front.
    • In the following step, you will undo the indicated pegs. PROCEED TO THE NEXT STEP.
    • Carefully holding the camera, grab the corresponding two points.
    • Carefully twist the lens assembly away from you. You will be turning your hand clockwise.
    • Pull lens assembly out.
    • The lens assembly is attached to the logic board by wire tape.
Conclusione
Bassem Tossoun
Membro da: 21/01/2011
201 Reputazione
2 Guide realizzate
Cal Poly, Team 4-29, Regan Winter 2011 Membro di Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,518
