Salta al contenuto principale
Panasonic KX-E603 Case Replacement
Cosa ti serve
  1. Panasonic KX-E603 Case Replacement, Case: passo 1, immagine 1 di 2 Panasonic KX-E603 Case Replacement, Case: passo 1, immagine 2 di 2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Case Replacement: passo 2, immagine 1 di 1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Case Replacement: passo 3, immagine 1 di 1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Case Replacement: passo 4, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 4, immagine 2 di 2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Case Replacement: passo 5, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 5, immagine 2 di 2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Case Replacement: passo 6, immagine 1 di 3 Panasonic KX-E603 Case Replacement: passo 6, immagine 2 di 3 Panasonic KX-E603 Case Replacement: passo 6, immagine 3 di 3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Case Replacement: passo 7, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 7, immagine 2 di 2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Case Replacement: passo 8, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 8, immagine 2 di 2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Case Replacement: passo 9, immagine 1 di 3 Panasonic KX-E603 Case Replacement: passo 9, immagine 2 di 3 Panasonic KX-E603 Case Replacement: passo 9, immagine 3 di 3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
Conclusione
Cal Poly, Team 17-1, Forte Spring 2015 Membro di Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 372
