Salta al contenuto principale
Disassembling Panasonic GU87 LCD Main Board
Cosa ti serve
  1. Disassembling Panasonic GU87 LCD Main Board, LCD Cover removal: passo 1, immagine 1 di 1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 LCD Main Board: passo 2, immagine 1 di 1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 LCD Main Board, LCD: passo 3, immagine 1 di 1
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 LCD Main Board: passo 4, immagine 1 di 1
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  5. Disassembling Panasonic GU87 LCD Main Board, Main Board: passo 5, immagine 1 di 1
    • Unlock the LCD connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  6. Disassembling Panasonic GU87 LCD Main Board: passo 6, immagine 1 di 1
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  7. Disassembling Panasonic GU87 LCD Main Board: passo 7, immagine 1 di 1
    • Pull/pivot the LCD main board as shown in order to remove.
Conclusione
Van
Membro da: 06/24/10
7 Reputazione
8 Guide realizzate
Cal Poly, Team 2-10, Johann Summer 2010 Membro di Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,812
