Salta al contenuto principale
Disassembling Panasonic GU87 Back cover
Cosa ti serve
  1. Disassembling Panasonic GU87 Back cover, Battery: passo 1, immagine 1 di 1
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Disassembling Panasonic GU87 Back cover: passo 2, immagine 1 di 1
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Disassembling Panasonic GU87 Back cover, Disassembling Panasonic GU87 Back cover: passo 3, immagine 1 di 1
    • Remove the rubber covers with tweezers.
  4. Disassembling Panasonic GU87 Back cover: passo 4, immagine 1 di 1
    • Remove all 4 screws from the back of the phone.
  5. Disassembling Panasonic GU87 Back cover: passo 5, immagine 1 di 1
    • Use a plastic opening tool to separate the front and back casing.
  6. Disassembling Panasonic GU87 Back cover: passo 6, immagine 1 di 1
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
Conclusione
Van
Membro da: 06/24/10
7 Reputazione
8 Guide realizzate
Cal Poly, Team 2-10, Johann Summer 2010 Membro di Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,177
