Introduzione
Use this guide to remove the side panels to access parts inside.
Strumenti
Parti
Nessuna parte richiesta.
Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
Charge the battery for 60-90 minutes if your battery is dead.
Remove the top screws using a 1.5 mm screwdriver.
Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
