Introduzione
This guide provides instructions for replacing a broken LCD screen on the Olympus Stylus 725.
Cosa ti serve
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
Remove the screws in the back panel using a Phillips #00 screwdriver.
Detach the ribbon cables that connect the LCD to the back panel of the camera.
