Salta al contenuto principale
Disassembling Olympus Stylus 725 SW Front Panel
Cosa ti serve
  1. Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: passo 1, immagine 1 di 2 Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: passo 1, immagine 2 di 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: passo 2, immagine 1 di 3 Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: passo 2, immagine 2 di 3 Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: passo 2, immagine 3 di 3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Conclusione
Bobby Hodges
Membro da: 04/18/10
49 Reputazione
6 Guide realizzate
Cal Poly, Team 33-71, Johann Spring 2010 Membro di Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,234
