Salta al contenuto principale
Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017)
Cosa ti serve
  1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: passo 1, immagine 1 di 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: passo 1, immagine 2 di 2
    • Plastic spudgers/opening tools
    • T2 Torx Screwdriver
  2. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the battery compartment: passo 2, immagine 1 di 1
    • Use a narrow-tipped object (such as a ballpoint pen or the tip of the T2 Torx Screwdriver) to depress the dimple on the battery compartment to release it
    • Replacement batteries are two (2) CR 2032 coin cell batteries.
  3. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: passo 3, immagine 1 di 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: passo 3, immagine 2 di 2
    • Gently pry along the edges of the remote using your fingers and prying tools to release the plastic clips.
    • It works best to start from the battery compartment and slowly work your way up to the top of the remote where the IR blaster is located.
    • Once the plastic clips are released, there is adhesive along the length of the volume sensor bar holding the front face in place. Slowly pry the face away from the rest of the remote and adjust your grip to avoid snapping the thin plastic face.
  4. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: passo 4, immagine 1 di 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: passo 4, immagine 2 di 2
    • There are (6) T2 Torx screws holding the mainboard to the frame of the remote.
    • Two clips hold the mainboard in place. Slightly lift the top of the mainboard up and slide it towards the top of the remote to remove it from the frame.
  5. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: passo 5, immagine 1 di 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: passo 5, immagine 2 di 2
    • The remote should now be fully disassembled.
Conclusione
Skeven
Membro da: 04/21/25
152 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 189
