Salta al contenuto principale
Disassembling Nokia E72
Cosa ti serve
  1. Disassembling Nokia E72, Nokia E72: passo 1, immagine 1 di 1
    • Here's the device before i started prying it open!
  2. Disassembling Nokia E72: passo 2, immagine 1 di 1
    • Remove metal backplate followed by the battery and then the SIM by pulling the SIM tray downwards. I do like this tray idea, but then again it's another thing that can go wrong with the device..
  3. Disassembling Nokia E72: passo 3, immagine 1 di 3 Disassembling Nokia E72: passo 3, immagine 2 di 3 Disassembling Nokia E72: passo 3, immagine 3 di 3
    • There are 2 screws on either side of the casing on the back of the E72.
    • Unscrew both screws using a T5 torx screwdriver
  4. Disassembling Nokia E72: passo 4, immagine 1 di 3 Disassembling Nokia E72: passo 4, immagine 2 di 3 Disassembling Nokia E72: passo 4, immagine 3 di 3
    • I used the opening device to un clip the silver front of the phone by inserting it at the point shown in the image and then running it down the side of the phone downwards (towards the bottom).
    • Rinse and repeat on the other side.
    • Then I ran the opening device carefully round the top edges of the phone, there was a clip at the very top.
    • Pulled the casing apart gently.
    • I now have the front and back part of the Nokia E72.
  5. Disassembling Nokia E72: passo 5, immagine 1 di 2 Disassembling Nokia E72: passo 5, immagine 2 di 2
    • I pulled the bottom edge of the keypad upwards, and then down away from the phone.
    • The keypad is latched by two metal connectors on the front face of the phone, when re-assembling make sure to latch them back in correctly.
  6. Disassembling Nokia E72: passo 6, immagine 1 di 2 Disassembling Nokia E72: passo 6, immagine 2 di 2
    • I needed to use the next size up of torx screwdriver for this set of screws.
    • Unscrewed the 2 screws on the bottom edge of the phone, this time T6 torx.
    • Followed by the top edge screws.
  7. Disassembling Nokia E72: passo 7, immagine 1 di 2 Disassembling Nokia E72: passo 7, immagine 2 di 2
    • The opening device was used to remove the connector for the display from the system board.
    • Then pulled the metal plate away from the system board by lifting the metal connectors circled in the picture and the sides of the screen plate also circled.
  8. Disassembling Nokia E72: passo 8, immagine 1 di 3 Disassembling Nokia E72: passo 8, immagine 2 di 3 Disassembling Nokia E72: passo 8, immagine 3 di 3
    • I then folded the metal plate over the bottom of the phone.
    • Used an opening device to remove the connector for the keyboard sensor pads.
    • Take away the metal plate from the system board.
  9. Disassembling Nokia E72: passo 9, immagine 1 di 2 Disassembling Nokia E72: passo 9, immagine 2 di 2
    • To remove the screen from the metal backing plate, apply some pressure to the back of the screen plate that you can see through the metal backing plate.
    • Alternatively I could have used a spudger or opening device to pry the screen away, though that may cause the metal back plate to bend.
  10. Disassembling Nokia E72: passo 10, immagine 1 di 3 Disassembling Nokia E72: passo 10, immagine 2 di 3 Disassembling Nokia E72: passo 10, immagine 3 di 3
    • I un-clipped the two rubberised connectors for the USB connector and the SD card, this made it easier for the system board to be removed.
    • I used an opening device to lift the system board from right hand side edge of the phone (it comes out easier from this end).
  11. Disassembling Nokia E72: passo 11, immagine 1 di 3 Disassembling Nokia E72: passo 11, immagine 2 di 3 Disassembling Nokia E72: passo 11, immagine 3 di 3
    • Removed the 3 button strip from the right hand side of the device.
    • Remove the microphone housing from the bottom of the device, this piece of kit also looks to be like the antenna looking at the markings and gold plating.
  12. Disassembling Nokia E72: passo 12, immagine 1 di 3 Disassembling Nokia E72: passo 12, immagine 2 di 3 Disassembling Nokia E72: passo 12, immagine 3 di 3
    • Poked the Power button out.
    • Pressed down on the right hand side of the LED flash to remove it.
    • Removed the speakers box.
  13. Disassembling Nokia E72: passo 13, immagine 1 di 3 Disassembling Nokia E72: passo 13, immagine 2 di 3 Disassembling Nokia E72: passo 13, immagine 3 di 3
    • Lifted the connector pin pad of the headphone socket, it is glued on by some adhesive foam.
    • Insert object into the headphone socket and force object downwards to remove headphone connector (it pops up at the back), perhaps inserting a headphone jack instead of a screwdriver would have been better!
  14. Disassembling Nokia E72: passo 14, immagine 1 di 2 Disassembling Nokia E72: passo 14, immagine 2 di 2
    • Ta-Da! This has to be the easiest phone to dissemble i have ever worked on. Only 6 screws on the entire device.
Conclusione
Very good device i think personally, with this disassembly you should be able to replace any part in the phone without an issue.
Altre 21 persone hanno completato questa guida.
James Stoy
Membro da: 07/30/10
1.798 Reputazione
1 Guida realizzata
6Commenti sulla guida
I have one of these, great tutorial. But on my phone, the screw drives used were one size down (T4/T5). Other than that, great!
Wes - Replica
How do I make up for Mike calls
m.hefzy18 - Replica
But can you assemble it back? Please write about that if you can!
jarkkoface - Replica
Hey I am 17 years old and my mom used her Nokia E72 to take pictures of me ever since she was pregnant with me. Unfortunately the phone fell into a pool of water and got water damaged. I was wonder if there is any memory card or any hardware that stores photos on this device that can be extracted and still accessed through a computer or another phone could you please get back to me and let me know? thank you!
Saatvik - Replica
How to solve the problem of Bluetooth which cannot be opened and everytime I tried to open it shows "unable to perform bluetooth operation"?
Iakmenlang mylliemumlong - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 65
Tutti i Tempi: 74,867
