Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parti
Nessuna parte specificata.
  1. To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it. Now slide the back cover off of the phone.
    • To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
    • Now slide the back cover off of the phone.
  2. Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
    • Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use your finger to lift the battery out.
    • Use your finger to lift the battery out.
    • The E61i uses a Nokia BP-4L standard battery.
  5. Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver. Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
    • Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
  6. After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
    • After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
Conclusione
Cal Poly, Team 9-63, Walters Spring 2011 Membro di Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,769
