Salta al contenuto principale
Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly
Cosa ti serve
  1. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: passo 1, immagine 1 di 2 Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: passo 1, immagine 2 di 2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 2, immagine 1 di 1
    • To remove the battery, push it down from the top and pull it out.
  3. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 3, immagine 1 di 1
    • Grip the front cover from the bottom.
  4. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 4, immagine 1 di 1
    • Lift the front cover off.
  5. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 5, immagine 1 di 1
    • Remove the six screws using a T6 torx screwdriver.
  6. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 6, immagine 1 di 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 7, immagine 1 di 1
    • Remove assembly from phone
Conclusione
Cal Poly, Team 22-3, Maness Fall 2010 Membro di Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,055
