Salta al contenuto principale
Disassembling Nokia 6236i Keypad
Cosa ti serve
  1. Disassembling Nokia 6236i Keypad, Battery: passo 1, immagine 1 di 2 Disassembling Nokia 6236i Keypad, Battery: passo 1, immagine 2 di 2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Disassembling Nokia 6236i Keypad: passo 2, immagine 1 di 3 Disassembling Nokia 6236i Keypad: passo 2, immagine 2 di 3 Disassembling Nokia 6236i Keypad: passo 2, immagine 3 di 3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Disassembling Nokia 6236i Keypad, Front Casing: passo 3, immagine 1 di 3 Disassembling Nokia 6236i Keypad, Front Casing: passo 3, immagine 2 di 3 Disassembling Nokia 6236i Keypad, Front Casing: passo 3, immagine 3 di 3
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
  4. Disassembling Nokia 6236i Keypad, Keypad: passo 4, immagine 1 di 1
    • With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • In all probability, it will already have fallen out and no removal is required.
Conclusione
Cal Poly, Team 10-46, Garner Spring 2010 Membro di Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 991
