Salta al contenuto principale
Disassembling Nokia 3560 Charging Port and Power Connector
Cosa ti serve
  1. Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: passo 1, immagine 1 di 2 Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: passo 1, immagine 2 di 2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Keypad: passo 2, immagine 1 di 1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Charging Port and Power Connector: passo 3, immagine 1 di 2 Disassembling Nokia 3560 Charging Port and Power Connector: passo 3, immagine 2 di 2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 LCD Display: passo 4, immagine 1 di 1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Charging Port and Power Connector: passo 5, immagine 1 di 1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Charging Port and Power Connector: passo 6, immagine 1 di 2 Disassembling Nokia 3560 Charging Port and Power Connector: passo 6, immagine 2 di 2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Charging Port and Power Connector: passo 7, immagine 1 di 1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Logic Board: passo 8, immagine 1 di 1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: passo 9, immagine 1 di 2 Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: passo 9, immagine 2 di 2
    • These two parts can be removed with your fingers.
    • Make sure not to bend the metal contacts.
Conclusione
Sam Ryan
Membro da: 04/18/10
1 Reputazione
8 Guide realizzate
Cal Poly, Team 30-39, Garner Spring 2010 Membro di Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,367
