Salta al contenuto principale
Disassembling Nokia 2366i Front Cover
Cosa ti serve
  1. Disassembling Nokia 2366i Front Cover, Battery: passo 1, immagine 1 di 2 Disassembling Nokia 2366i Front Cover, Battery: passo 1, immagine 2 di 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Cover: passo 2, immagine 1 di 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Cover: passo 3, immagine 1 di 3 Disassembling Nokia 2366i Front Cover: passo 3, immagine 2 di 3 Disassembling Nokia 2366i Front Cover: passo 3, immagine 3 di 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Cover, Front Cover: passo 4, immagine 1 di 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Cover: passo 5, immagine 1 di 2 Disassembling Nokia 2366i Front Cover: passo 5, immagine 2 di 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Cover: passo 6, immagine 1 di 2 Disassembling Nokia 2366i Front Cover: passo 6, immagine 2 di 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
Conclusione
Kristen
Membro da: 01/17/11
175 Reputazione
1 Guida realizzata
Cal Poly, Team 1-14, Amido Winter 2011 Membro di Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,181
