Salta al contenuto principale
Disassembling Nokia 1110i (RH-93) made in Hongrie
Cosa ti serve
  1. Disassembling Nokia 1110i (RH-93) made in Hongrie, Phone: passo 1, immagine 1 di 3 Disassembling Nokia 1110i (RH-93) made in Hongrie, Phone: passo 1, immagine 2 di 3 Disassembling Nokia 1110i (RH-93) made in Hongrie, Phone: passo 1, immagine 3 di 3
    • Switch off the device to avoid shocks while disassembling.
    • Turn the device face down and press on the small button at the bottom . Slide the back case down.
    • To remove the battery, use your finger to insert it in the groove and pull the battery out.
  2. Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 2, immagine 1 di 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 2, immagine 2 di 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 2, immagine 3 di 3
    • To remove the protective cover, use the tool shown and press the grey button at the left bottom.
    • The front cover ejects as shown. Remove it carefully to avoid damage.
    • The keypad case can be removed easily. Pull it up off the device.
    • Use a T6 Torx screwdriver to remove the screws.
  3. Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 3, immagine 1 di 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 3, immagine 2 di 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Find this channel at the top of your device.
    • Use a pair of tweezers to remove it carefully without harming the surroundings.
    • Insert the spudger into the section to remove the module.
  4. Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 4, immagine 1 di 2 Disassembling Nokia 1110i (RH-93) made in Hongrie: passo 4, immagine 2 di 2
    • Use the spudger to remove the module casing safely.
    • Your device is successfully disassembled.
Conclusione
Altre 15 persone hanno completato questa guida.
JDU TV
Membro da: 09/15/13
3.432 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 46
Tutti i Tempi: 4,272
