Introduzione
You will be walked through the steps to reveal the internal workings of the Firestrike. From here you will be able to replace any portion of the Firestrike. You will only need a #1 Phillips Screwdriver and your hands. This guide is quick and easy and can be completed anywhere.
Cosa ti serve
Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
