Introduzione
This guide demonstrates how to disassemble the G700 mouse in order to reach the top mouse buttons for cleaning.
The mouse will be broken down into three main components: The circuit board, top housing, and middle housing.
Cosa ti serve
Unplug the USB cord from the top of the mouse.
Peel off the four sticker pads located on the bottom of the mouse. They will be on the top, bottom and sides.
Stick these pads onto a clean, flat surface for safe keeping as you continue to disassemble the mouse.
Press the side keys toward the bottom of the housing.
This will detach the keys and wires from the housing.
u need to push the inside upward out of the slot before pushing the side keys in. ive break part of the slot by following this….
Altre 34 persone hanno completato questa guida.
7 Commenti
I did open my mouse to clean but I open the wheel too. Inside are to support torqued springs that I do not know how to put them back. in this case my mouse wheel is not working properly. Can you please help me with some pictures or an advice?
The small springs are located in the front of the mouse, left and right from the switch which is used for the middle mouse button. i would take an photo if I could. I had the same problem before but found the solution.
egal -
Tengo un mouse logitech g502 de los primeros y la verdad que estaba muy contento con él, por el tema de que trae 2 botones a cada lado y me viene bien para macros. El uso sería juegos (CSGO o BF3/4) y autocad y Catia.
Yo utilizo tableta gráfica XP-Pen Star G430S para jugar al osu y hacer anotaciones, subrayar y corregir pequeñas cosas en los apuntes que tengo en formato word y PDF , pero he empezado a dibujar con ella y va genial.
