Salta al contenuto principale
Motorola V180 Connector Ribbon Replacement
Cosa ti serve
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: passo 1, immagine 1 di 1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: passo 2, immagine 1 di 1
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: passo 3, immagine 1 di 1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: passo 5, immagine 1 di 1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: passo 6, immagine 1 di 1
    • Use a soldering iron to detach the connector ribbon from the phone.
Conclusione
Cal Poly, Team 6-16, Maness Spring 2010 Membro di Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,629
