Salta al contenuto principale
Introduzione
Disassembling top half to get to connector ribbon, inside screen, and speaker.
  1. Pull at top of faceplate, and it will pop off.
    • Pull at top of faceplate, and it will pop off.
  2. Unscrew four screws on front cover.
    • Unscrew four screws on front cover.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Slide out metallic silver cover.
    • Slide out metallic silver cover.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  5. Use a tool to wedge in between the silver and black parts on the cover.
    • Use a tool to wedge in between the silver and black parts on the cover.
    • Silver part should now snap off.
  6. Black rubber part may now be easily removed.
    • Black rubber part may now be easily removed.
  7. Use a soldering iron to disconnect the connector ribbon from the phone.
    • Use a soldering iron to disconnect the connector ribbon from the phone.
Conclusione
Cal Poly, Team 6-16, Maness Spring 2010 Membro di Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,523
