Salta al contenuto principale
Disassembling ModRetro Chromatic (Released Mid-2025)
Cosa ti serve
  1. Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover and Batteries: passo 1, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover and Batteries: passo 1, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover and Batteries: passo 1, immagine 3 di 3
    • To remove the battery cover, push upward on the battery cover lock. The battery cover will pop open.
    • Lift the battery cover off and set aside.
    • Remove the batteries.
    • Always remove the batteries before working on your Chromatic!
  2. Disassembling ModRetro Chromatic (Released Mid-2025), Back Shell: passo 2, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Back Shell: passo 2, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Back Shell: passo 2, immagine 3 di 3
    • Remove the back shell screws (x4) using a Tri-wing Y1 Screwdriver.
    • A Tri-wing Y1.5 will also work for all screws.
    • The screws near the top are a different length than the screws near the bottom of the shell.
    • Remove the back shell by lifting away from the device.
  3. Disassembling ModRetro Chromatic (Released Mid-2025), Menu Button: passo 3, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Menu Button: passo 3, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Menu Button: passo 3, immagine 3 di 3
    • Remove the menu button by lifting it off the post. It will remove with little to no resistance.
  4. Disassembling ModRetro Chromatic (Released Mid-2025), Battery Tray: passo 4, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Tray: passo 4, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Tray: passo 4, immagine 3 di 3
    • Remove the battery tray screws (x3) using a Tri-wing Y1 Screwdriver.
    • Remove the battery tray connector.
    • It is helpful to press lightly against the PCB with your off hand while working the connector loose.
  5. Disassembling ModRetro Chromatic (Released Mid-2025), PCB: passo 5, immagine 1 di 2 Disassembling ModRetro Chromatic (Released Mid-2025), PCB: passo 5, immagine 2 di 2
    • Carefully lift the LCD screen ribbon cable from the PCB.
    • Handle with care!
    • Carefully remove the PCB from the front shell.
    • Lifting at a slight angle will help clear the headphone jack on the bottom more easily. This is also important during re-assembly.
  6. Disassembling ModRetro Chromatic (Released Mid-2025), Speaker Module: passo 6, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Speaker Module: passo 6, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Speaker Module: passo 6, immagine 3 di 3
    • Remove the speaker module screw (x1) using a Tri-wing Y1 Screwdriver.
    • Carefully remove the speaker module from the front shell.
  7. Disassembling ModRetro Chromatic (Released Mid-2025), Light Pipe: passo 7, immagine 1 di 2 Disassembling ModRetro Chromatic (Released Mid-2025), Light Pipe: passo 7, immagine 2 di 2
    • Remove the light pipe screw (x1) using a Tri-wing Y1 Screwdriver.
  8. Disassembling ModRetro Chromatic (Released Mid-2025), Buttons and Membranes: passo 8, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Buttons and Membranes: passo 8, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Buttons and Membranes: passo 8, immagine 3 di 3
    • Remove the rubber button membranes (x3) from their pockets.
    • Remove the buttons and the D-pad from the shell with tweezers or by hand. If you flip the shell over, they will fall out freely.
    • The buttons will come out easily once the membranes are removed.
    • When re-attaching the rubber button membranes, be sure the positive features on the membranes seat securely into the pockets on the shell.
  9. Disassembling ModRetro Chromatic (Released Mid-2025), IR Window: passo 9, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), IR Window: passo 9, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), IR Window: passo 9, immagine 3 di 3
    • Carefully separate the IR window by gently wedging a plastic spudger between the IR window and the front shell.
    • Re-installing the IR window:
    • Note the side with the lip is inserted towards the front shell first.
    • Press in firmly until fully seated against the shell.
    • If the IR window fits loosely, the orientation is incorrect. The fit should be snug.
  10. Disassembling ModRetro Chromatic (Released Mid-2025), Power Switch: passo 10, immagine 1 di 1
    • Remove the power switch by lifting away from the front shell. It will remove with little resistance.
    • When re-assembling the power switch, make sure it is inserted in the OFF position.
  11. Disassembling ModRetro Chromatic (Released Mid-2025), Cartridge Backer: passo 11, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Cartridge Backer: passo 11, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Cartridge Backer: passo 11, immagine 3 di 3
    • Remove the cartridge backer screws (x4) using a Tri-wing Y1 Screwdriver.
  12. Disassembling ModRetro Chromatic (Released Mid-2025), Latch Catch: passo 12, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Latch Catch: passo 12, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Latch Catch: passo 12, immagine 3 di 3
    • Remove the latch catch screws (x4) using a Tri-wing Y1 Screwdriver.
    • Gently push the latch up from the back using your finger.
  13. Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover: passo 13, immagine 1 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover: passo 13, immagine 2 di 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover: passo 13, immagine 3 di 3
    • Remove the screws (x2) securing the latch cover using a Tri-wing Y1 Screwdriver.
    • Remove the door plate spring by fully depressing the battery cover lock. The spring should pop out.
    • Use a spudger if the spring does not fully dislodge.
    • Once the spring is removed, the battery cover lock can be removed without resistance through the underside of the battery cover.
Conclusione
cj@modretro
Membro da: 08/05/25
229 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 119
Ultimi 30 Giorni: 347
Tutti i Tempi: 916
