Salta al contenuto principale
Disassembling Midland X-tra Talk Radio LXT118 Speaker
Cosa ti serve
  1. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: passo 1, immagine 1 di 2 Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: passo 1, immagine 2 di 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Speaker: passo 2, immagine 1 di 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Case: passo 3, immagine 1 di 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Speaker: passo 4, immagine 1 di 1
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Speaker: passo 5, immagine 1 di 1
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Disassembling Midland X-tra Talk Radio LXT118 Speaker: passo 6, immagine 1 di 1
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Disassembling Midland X-tra Talk Radio LXT118 Speaker: passo 7, immagine 1 di 1
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Disassembling Midland X-tra Talk Radio LXT118 Speaker: passo 8, immagine 1 di 1
    • The speaker is now disassembled!
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 19-43, Regan Winter 2013 Membro di Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 590
