Salta al contenuto principale
Disassembling Midland X-tra Talk Radio LXT118 Circuit Board
Cosa ti serve
  1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: passo 1, immagine 1 di 2 Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: passo 1, immagine 2 di 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: passo 2, immagine 1 di 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Case: passo 3, immagine 1 di 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: passo 4, immagine 1 di 1
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Midland X-tra Talk Radio LXT118: passo 5, immagine 1 di 1
    • Remove the old or broken circuit board from the front case by carefully separating it from the back.
    • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
Conclusione
To reassemble your device, follow these instructions in reverse order, from step 6 to 1.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 19-43, Regan Winter 2013 Membro di Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 890
