Introduzione
The Circuit board has the screen and microphone attached, but the speaker and antenna can be modified separately.
First, apply pressure with your thumb on the top of the battery cover.
  • First, apply pressure with your thumb on the top of the battery cover.
Aggiungi Commento
Next, pull down on the cover until it begins to slide.
  • Next, pull down on the cover until it begins to slide.
Aggiungi Commento
  • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
Aggiungi Commento
  • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
Aggiungi Commento
  • Detach back part of the case by gently lifting up.
Aggiungi Commento
  • Remove the old or broken circuit board from the front case.
  • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 19-43, Regan Winter 2013 Membro di Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 621
