Salta al contenuto principale
Disassembling Microtek ScanMaker 5900 Motor Tread
Cosa ti serve
  1. Disassembling Microtek ScanMaker 5900 Motor Tread, Remove serial port connection: passo 1, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove serial port connection: passo 1, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove serial port connection: passo 1, immagine 3 di 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Disassembling Microtek ScanMaker 5900 Motor Tread, Remove Lid: passo 2, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove Lid: passo 2, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove Lid: passo 2, immagine 3 di 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Disassembling Microtek ScanMaker 5900 Motor Tread, Detach plastic latches: passo 3, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Detach plastic latches: passo 3, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Detach plastic latches: passo 3, immagine 3 di 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Disassembling Microtek ScanMaker 5900 Motor Tread, Continue latch detachment: passo 4, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Continue latch detachment: passo 4, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Continue latch detachment: passo 4, immagine 3 di 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Disassembling Microtek ScanMaker 5900 Motor Tread, Fully remove the upper lid: passo 5, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Fully remove the upper lid: passo 5, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Fully remove the upper lid: passo 5, immagine 3 di 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Disassembling Microtek ScanMaker 5900 Motor Tread, Stepper Motor: passo 6, immagine 1 di 2 Disassembling Microtek ScanMaker 5900 Motor Tread, Stepper Motor: passo 6, immagine 2 di 2
    • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
    • Disconnect the white connector from the vertical standing circuit board.
  7. Disassembling Microtek ScanMaker 5900 Motor Tread: passo 7, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread: passo 7, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread: passo 7, immagine 3 di 3
    • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
    • The stepper motor will become loose, but not completely free.
  8. Disassembling Microtek ScanMaker 5900 Motor Tread: passo 8, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread: passo 8, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Motor Tread: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers gently remove the tread from the black gear on the stepper motor.
    • The stepper motor will become completely free.
  9. Disassembling Microtek ScanMaker 5900 Motor Tread, Motor Tread: passo 9, immagine 1 di 2 Disassembling Microtek ScanMaker 5900 Motor Tread, Motor Tread: passo 9, immagine 2 di 2
    • Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread.
    • Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
    • Using a #2 Philips Screwdriver, unscrew the single 5.88mm screw holding the mount of the plastic wheel in place.
  10. Disassembling Microtek ScanMaker 5900 Motor Tread: passo 10, immagine 1 di 1
    • The plastic wheel and it's mount will be loose.
    • Remove the shaft holding the plastic wheel and the mount together
    • The tread will be completely loose.
Conclusione
Cal Poly, Team 6-9, Regan Fall 2011 Membro di Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,354
