Salta al contenuto principale
Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case
Cosa ti serve
  1. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: passo 1, immagine 1 di 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: passo 1, immagine 2 di 2
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: passo 2, immagine 1 di 1
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: passo 3, immagine 1 di 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: passo 3, immagine 2 di 2
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: passo 4, immagine 1 di 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: passo 4, immagine 2 di 2
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
Conclusione
Altre 4 persone hanno completato questa guida.
RoggeSound
Membro da: 06/05/10
2.345 Reputazione
1 Guida realizzata
2 Commenti
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - Replica
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 6,752
