Salta al contenuto principale
Disassembling Mercedes W123 Kick Panel
Cosa ti serve
  1. Disassembling Mercedes W123 Kick Panel, Kick Panel: passo 1, immagine 1 di 1
    • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
  2. Disassembling Mercedes W123 Kick Panel: passo 2, immagine 1 di 1
    • Then remove these screws.
  3. Disassembling Mercedes W123 Kick Panel: passo 3, immagine 1 di 2 Disassembling Mercedes W123 Kick Panel: passo 3, immagine 2 di 2
    • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
  4. Disassembling Mercedes W123 Kick Panel: passo 4, immagine 1 di 2 Disassembling Mercedes W123 Kick Panel: passo 4, immagine 2 di 2
    • Now lower the panel down and rest if on the floor.
    • It can be removed full for further ease of access, depending on the job at hand.
  5. Disassembling Mercedes W123 Kick Panel: passo 5, immagine 1 di 3 Disassembling Mercedes W123 Kick Panel: passo 5, immagine 2 di 3 Disassembling Mercedes W123 Kick Panel: passo 5, immagine 3 di 3
    • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
    • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
    • Heater blower motor
    • Over-voltage protection relay
    • Air-conditioning expansion valve
Conclusione
Altre 11 persone hanno completato questa guida.
Nicolas Siemsen
Membro da: 12/06/13
39.284 Reputazione
79 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.525 Guide realizzate
Un commento
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 77
Tutti i Tempi: 13,661
