Salta al contenuto principale
Disassembling Marshall MS-2 Partner Circuit Board
Cosa ti serve
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: passo 1, immagine 1 di 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: passo 2, immagine 1 di 3 Disassembling Marshall MS-2 Partner Circuit Board: passo 2, immagine 2 di 3 Disassembling Marshall MS-2 Partner Circuit Board: passo 2, immagine 3 di 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: passo 3, immagine 1 di 2 Disassembling Marshall MS-2 Partner Circuit Board: passo 3, immagine 2 di 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: passo 4, immagine 1 di 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: passo 5, immagine 1 di 2 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: passo 5, immagine 2 di 2
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: passo 6, immagine 1 di 1
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: passo 7, immagine 1 di 1
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
There Is a toroidal transformer inside ?
Jack redmond - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,041
