Salta al contenuto principale
Disassembling Macintosh IIsi Power Supply
Cosa ti serve
  1. Disassembling Macintosh IIsi Power Supply, Top Case: passo 1, immagine 1 di 2 Disassembling Macintosh IIsi Power Supply, Top Case: passo 1, immagine 2 di 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Power Supply: passo 2, immagine 1 di 3 Disassembling Macintosh IIsi Power Supply: passo 2, immagine 2 di 3 Disassembling Macintosh IIsi Power Supply: passo 2, immagine 3 di 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Power Supply, Floppy Drive: passo 3, immagine 1 di 3 Disassembling Macintosh IIsi Power Supply, Floppy Drive: passo 3, immagine 2 di 3 Disassembling Macintosh IIsi Power Supply, Floppy Drive: passo 3, immagine 3 di 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Power Supply: passo 4, immagine 1 di 3 Disassembling Macintosh IIsi Power Supply: passo 4, immagine 2 di 3 Disassembling Macintosh IIsi Power Supply: passo 4, immagine 3 di 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
  5. Disassembling Macintosh IIsi Power Supply, System Fan: passo 5, immagine 1 di 1
    • The fan recieves power from two contacts on the logic board and has no connector.
  6. Disassembling Macintosh IIsi Power Supply: passo 6, immagine 1 di 3 Disassembling Macintosh IIsi Power Supply: passo 6, immagine 2 di 3 Disassembling Macintosh IIsi Power Supply: passo 6, immagine 3 di 3
    • In all of the years that I have worked on this machine, I have found no good way to remove the fan.
    • The best way to start, is to push in here on the side of the fan.
    • Being careful not to exert too much force, try to push in, and wiggle the fan outward as such. (2nd Photo)
    • You can now lift the fan all the way out, and remove it.
    • The Fan Power Contacts on the Logic Board:
  7. Disassembling Macintosh IIsi Power Supply, Power Supply: passo 7, immagine 1 di 2 Disassembling Macintosh IIsi Power Supply, Power Supply: passo 7, immagine 2 di 2
    • To remove the power supply, squeeze these two tabs and lift the front up.
    • On the back of the power supply, there is a tab that also must be pressed to remove the power supply fully. You can then lift it out all the way. A firm tug may be necessary to seperate the power connector.
  8. Disassembling Macintosh IIsi Power Supply: passo 8, immagine 1 di 2 Disassembling Macintosh IIsi Power Supply: passo 8, immagine 2 di 2
    • Information on the power supply:
    • It was made by Sony in 1990, and uses a 10-Pin power connector.
Conclusione
Altre 2 persone hanno completato questa guida.
Chris Green
Membro da: 10/11/09
37.014 Reputazione
49 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.541 Guide realizzate
Un commento
I was looking for the schematic for the power supply APS-06 pictured here. The information above would be a little helpful if one was really unaware of anything electromechanical,… otherwise, it’s all pretty obvious I think.
nikitesla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,553
