Introduzione
La maggior parte delle viti che sviterai sono avvitate nella plastica: stai attento mentre le riavviti in quanto possono spanarsi facilmente o rompere la plastica.
Cosa ti serve
Svita le sei viti grigie esagonali da 25 mm con una chiave a brugola da 4 mm.
Solleva attentamente il volante, ma non scollegarlo dal resto del dispositivo.
Schiaccia e scollega attentamente il connettore largo a 7 pin sotto la scheda PCB.
These screws refused to go all the way back in for me, and one of them stripped completely. If this happens to you, you can get replacement screws that are shorter here - https://www.amazon.com/gp/product/B01MFA...
This works for the G27, not sure about the G25 or any other wheels.
Obviously the screws being shorter means the wheel isn't as strongly attached to the base in this direction, so if you have to do this remember not to put unnecessary stress on these screws by pulling the wheel straight off the base.
bro i need new long cable i think and that connector or just replace the whole thing .. i put new grease, screw it more tight by the encoder so it woulnt go to the left .. wheel works verry nice tho all my buttons and shifter pedals wont work now tho the lights works dont know what to do now.. and now i kinda regreat opening it.. my wheel run so good now just these buttons are off not working at all and it kinda screws up midle of the game..
@alexdinpoik I’ve had the same problem when the 7 pin connectors blue and green cables broke off. First, only the blue one was broken which only took the led indicators gradual increase but all buttons were working then when i tried to plug in back, the green one broke off leading to none of the buttons working but the led indicators just working. Now i’ll try to fix it with iron soldering.
okan can u pls share a video of you doing it? so i can do the “copy paste” hahah where can i buy cables and stuff i need for that? whats the name of these white connectors ? im new to this but share me a link to buy. i rather just try to fix it then buy a new wheel since its a great wheel compare to g29 that has bad software and the other wheels are to expensive. g27 cant be found in stores anymore neither and if im gonna buy one it has to be new haha hopefully u can share some knowlage thanks!
Where i can Buy the 7 pin cable for Main board please
Hey guys!
i broke the 7 pin cable anyone know where can is buy it? Thanks
Ruta la copertura a testa in su e rimuovine la metà superiore, svelando la maggior parte dei componenti del volante.
Puoi mettere da parte la copertura del volante finché non lo rimonti.
Loosen the desk clamps before removing the housing, otherwise you risk breaking something. The housing should come off without having to use any force whatsoever.
Svita le quattro viti argento da 7,3 mm che fissano la scheda PCB verde alla copertura del motore con un cacciavite a croce Phillips #2.
I’d do steps 9 and 10 in reverse order, the connectors are much easier to unplug while the board is secured in place.
Scollega i tre connettori in plastica sulla parte sinistra della scheda PCB.
Scollega i due connettori in plastica sulla parte superiore della scheda PCB.
Scollega i tre connettori in plastica sulla parte destra della scheda PCB.
Some of the connectors have locks on them, I would recommend this as a two person job.
I didn't take them off :)
I messed up and broke the cables of the 5 Pin Connector on the right. Can anyone tell me what it’s called so I can buy replacement? The Rest of the cable is stuck in there so I can’t re-use it sadly.
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Altre 9 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Un commento
Hi - help please. I disassembled my G27 and a 2 inch long semicircular metal clip fell out during the process. I don’t know what it is or where it came from.
Fijar primero el volante en la mesa para evitar desperfectos.
Alpc360 - Replica
