Introduzione
The guide is designed specifically for the LG Vortex phone. This guide gives detailed instructions on the removal of the back case and the face from the frame.
Cosa ti serve
Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
Remove the back cover and set it to the side.
Use the precision screwdriver to remove the 6 screws along the edges of the phone.
There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
Use the blue plastic opening tool to remove the back frame from the rest of the phone.
Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
Pry your way around the entire phone to separate the face from the frame.
Altre 2 persone hanno completato questa guida.
