Introduzione
This guide shows how to disassemble the rear casing on a LG 440G to access the electronics.
This disassembly requires 2 tools, a Phillips #00 screw driver and an opening tool.
Cosa ti serve
Slide the rear cover downward
Lift it off to access the battery
Locate the small rounded recess to get access to the battery
Gently, lift the battery
Use a Phillips #00 screw driver to remove six screws.
Run the plastic opening tool along the edge of the phone to release the casing cover.
Lift the casing cover.
Un commento
this would be most probably, the same guide to tear down the LG B470
