Introduzione
You might want to remove the latchdoor to get better access to the DC micromotor.
Cosa ti serve
These 4 screws are all that holds the latchdoor connected to the body.
It also holds the metal that will keep the film cartridge in place. This is a seperate piece that lays underneath the latch.
Make sure that you lay a piece of cloth inside the empty film case, this to prevent loose screws to dissapear in the little hole that is located on the top left side.
Now simply unscrew the 4 screws and the door should come off flawlessly.
To reassemble your device, follow these instructions in reverse order. Make sure the hinge-part is underneath the latchdoor, not on top of it!
