Salta al contenuto principale
Disassembling Kodak Advantix F350 Back Cover
Cosa ti serve
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: passo 1, immagine 1 di 1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: passo 2, immagine 1 di 2 Disassembling Kodak Advantix F350 Back Cover: passo 2, immagine 2 di 2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: passo 3, immagine 1 di 3 Disassembling Kodak Advantix F350 Back Cover: passo 3, immagine 2 di 3 Disassembling Kodak Advantix F350 Back Cover: passo 3, immagine 3 di 3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: passo 4, immagine 1 di 2 Disassembling Kodak Advantix F350 Back Cover: passo 4, immagine 2 di 2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: passo 5, immagine 1 di 2 Disassembling Kodak Advantix F350 Back Cover: passo 5, immagine 2 di 2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: passo 6, immagine 1 di 3 Disassembling Kodak Advantix F350 Back Cover: passo 6, immagine 2 di 3 Disassembling Kodak Advantix F350 Back Cover: passo 6, immagine 3 di 3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Conclusione
UW Stout, Team 1-2, Zhou Fall 2011 Membro di UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,080
