Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Parti
Nessuna parte specificata.
  1. With the needle removed, open the device by pulling up on the handle.
    • With the needle removed, open the device by pulling up on the handle.
  2. Push in on one of the arms attached to the K-cup holder plastic housing to remove it from its rails.  The arms are identical for both sides so once one side is free repeat the process for the second side. The plastic is flexible and will not snap with the force applied. Once the arms are removed, the configuration should look like the picture. The K-cup holder housing should be separated from the arms.
    • Push in on one of the arms attached to the K-cup holder plastic housing to remove it from its rails. The arms are identical for both sides so once one side is free repeat the process for the second side.
    • The plastic is flexible and will not snap with the force applied.
    • Once the arms are removed, the configuration should look like the picture. The K-cup holder housing should be separated from the arms.
  3. Use a Phillips #1 screw driver to remove the four 12 mm screws that hold the arm assembly in place.
    • Use a Phillips #1 screw driver to remove the four 12 mm screws that hold the arm assembly in place.
  4. Lift up the arm and pull up the handle assembly. It should easily come off. This white tab falls off easily, remove it and set it aside to ensure it is not lost.
    • Lift up the arm and pull up the handle assembly. It should easily come off.
    • This white tab falls off easily, remove it and set it aside to ensure it is not lost.
Conclusione
Andrew Adriance
Membro da: 14/01/2014
1.848 Reputazione
7 Guide realizzate
Cal Poly, Team 17-1, Forte Winter 2014 Membro di Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 62
