Salta al contenuto principale
Disassembling JVC GR-D290U
Cosa ti serve
  1. Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: passo 1, immagine 1 di 2 Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: passo 1, immagine 2 di 2
    • Open the liquid-crystal display (LCD) screen.
    • Using a Phillips #1 screwdriver, remove the two hinge screws.
    • Remove the hinge cover. Shut the screen after the cover is removed.
  2. Disassembling JVC GR-D290U: passo 2, immagine 1 di 3 Disassembling JVC GR-D290U: passo 2, immagine 2 di 3 Disassembling JVC GR-D290U: passo 2, immagine 3 di 3
    • Flip the camera over to look at the bottom panel.
    • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
    • Push the eject button beneath the bottom panel to open the cassette cover.
    • Shut the cassette cover.
    • Place the camera upright.
  3. Disassembling JVC GR-D290U: passo 3, immagine 1 di 1
    • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
    • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
    • Replace the dark gray tab and close the LCD screen.
  4. Disassembling JVC GR-D290U: passo 4, immagine 1 di 1
    • Go to the side of the camera that is opposite the LCD screen.
    • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
  5. Disassembling JVC GR-D290U: passo 5, immagine 1 di 2 Disassembling JVC GR-D290U: passo 5, immagine 2 di 2
    • Go to the side of the camera that has the LCD screen.
    • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
    • Pry the top cover from the bottom cover until you hear a snapping sound.
    • Gently remove the top cover from the camera base.
Conclusione
Altre 2 persone hanno completato questa guida.
justin chen
Membro da: 04/27/10
47 Reputazione
3 Guide realizzate
Cal Poly, Team 18-69, Johann Spring 2010 Membro di Cal Poly, Team 18-69, Johann Spring 2010
CPSU-JOHANN-S10S18G69
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,881
