Salta al contenuto principale
Introduzione
The plastic edge cover needs to be removed to get to some components.
Parti
Nessuna parte specificata.
  1. Unscrew the 20 Phillips screws on the underside of the T42.
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. Unscrew the 2 Phillips screws on both sides of the T42's rear.
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  5. Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  6. Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed. Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
    • Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
Conclusione
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
30 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 6,575
