Salta al contenuto principale
Disassembling Home Stereo and Theater Philips MCD288
Cosa ti serve
  1. Disassembling Home Stereo and Theater Philips MCD288, Undo screws: passo 1, immagine 1 di 1
    • remove the 4 screws on the bottem of the main set
  2. Disassembling Home Stereo and Theater Philips MCD288, Expose main latches: passo 2, immagine 1 di 1
    • Lift the aluminium pane at both sides with a spudger.
  3. Disassembling Home Stereo and Theater Philips MCD288, Start with the bottom edges: passo 3, immagine 1 di 1
    • To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
    • hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
  4. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: passo 4, immagine 1 di 2 Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: passo 4, immagine 2 di 2
    • To detach the sides, pull a main latch towards you and keep on lifting the top part further.
    • repeat for three latches on each side.
  5. Disassembling Home Stereo and Theater Philips MCD288, The inside: passo 5, immagine 1 di 2 Disassembling Home Stereo and Theater Philips MCD288, The inside: passo 5, immagine 2 di 2
    • These pictures show the latches on each edge and on the top of the set.
Conclusione
Altre 2 persone hanno completato questa guida.
Philipp
Membro da: 03/16/15
71 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 52
Tutti i Tempi: 7,322
