Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Be sure to remove the ink-cartridges and unplug the printer before beginning dis assembly of the device.
Parti
Nessuna parte specificata.
  1. Before disassembling your printer, be sure that the printer has been unplugged. Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Before disassembling your printer, be sure that the printer has been unplugged.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Firmly pull the the back of the side panel until it separates from the body of the printer. Rotate the side panel upwards while pulling it towards yourself to remove the panel.
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Rotate the printer 90 degrees clockwise. Grasp the paper tray and rotate it down.
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Rotate the printer 90 degrees clockwise. Remove the two T10 12 mm Torx screws.
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Rotate the printer 90 degrees counter clockwise. Lift the scanner lid to expose the scanner glass.
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Remove the two T10 12 mm Torx screws.
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Rotate the printer 90 degrees counter clockwise. Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. Rotate the printer 90 degrees clockwise. Remove the cable connecting the top panel of the printer to the power button assembly.
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Carefully lift the top panel of the printer away from the printer body.
    • Carefully lift the top panel of the printer away from the printer body.
Conclusione
Altre 7 persone hanno completato questa guida.
Jim
Membro da: 06/10/2011
1.083 Reputazione
10 Guide realizzate
Cal Poly, Team 20-30, Maness Fall 2011 Membro di Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Membri
25 Guide realizzate
Thanks... Now I'know how clean
Diogo Pires Nunes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,410
