Introduzione
Disassembling the printer is relatively simple, and involving only one screw being removed and some cables being unplugged.
Cosa ti serve
First, begin by removing the printer's hood.
Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
Adjust the flap covering the scanner upward, as shown.
To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
After pressing the clip, pull out the power button panel by pulling from right to left.
This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
When all three cables are removed, lift the hood away from the printer and set it aside.
After being separated from the printer, the hood is ready to be disassembled.
Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
Set the piece of the hood down such that no stress is applied to the scanner as it is attached by ribbon cable.
Altre 19 persone hanno completato questa guida.
9 Commenti
Thanks for this guide. I never would have found that fourth screw without this guide. The illustration of the "clip" for removal of the power quadrant face could have been more detailed and/or you could have said in the description, "Feel for the TAB on the right center of the power button quadrant behind the "cartridge door open" feeler and push it toward the outside of the printer". Other than that, this was great.
Great Support,.!!!
I am a handy person and a Computer tech for family and friends,.
Some time You just need Instruction on how to do do things, Other wise You taking the risks of braking things instead of fixing them
Thanks Guys
Thank you for posting this. In place of the pliers, I recommend using a small reversible ratchet offset (mine was 3-1/4"W x 6-3/4"L x 1/2"H) to remove the 4th screw. It won't slide of the screw like pliers and will make both the removal and replacement much easier.
Where can I find spare parts for HP PSC photosmart D110?
Regards
Hi please I need some help I have this printer and I can’t print wireless I have an Error says
server connection error
There was a problem conectinng to the server
I try everything no luck I resetting a factory default
no working please sent me any information thanks
Hi I have the same printer I used with the WiFi
all the time I change the company Internet now I can’t connect WiFi I have a message saying
server connection error !!!
please help I did a reset no luck please instructions
how to fix it thanks.
Does anyone know whee to purchase parts for the D110? I just need several parts…the drive belt for the print head mechanism, and one of the cam operated stops that keeps the print head from moving to the right side of the mechanism. Thanks for any information available. 3-19-2020
Harry
It was very helpful
