Salta al contenuto principale
Disassembling HP Pavilion g7-2275dx Front Panel
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Disassembling HP Pavilion g7-2275dx Front Panel, Front Panel: passo 1, immagine 1 di 1
    • Unscrew the four 7 mm Phillips #1 screws on the board.
  2. Disassembling HP Pavilion g7-2275dx Front Panel: passo 2, immagine 1 di 3 Disassembling HP Pavilion g7-2275dx Front Panel: passo 2, immagine 2 di 3 Disassembling HP Pavilion g7-2275dx Front Panel: passo 2, immagine 3 di 3
    • Use a plastic opening tool to lift the white clip up, towards the screen.
    • Pull the white cable with blue head, away from the clip.
  3. Disassembling HP Pavilion g7-2275dx Front Panel: passo 3, immagine 1 di 2 Disassembling HP Pavilion g7-2275dx Front Panel: passo 3, immagine 2 di 2
    • With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
    • If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • You should hear clips releasing from the board.
  4. Disassembling HP Pavilion g7-2275dx Front Panel: passo 4, immagine 1 di 1
    • Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
  5. Disassembling HP Pavilion g7-2275dx Front Panel: passo 5, immagine 1 di 2 Disassembling HP Pavilion g7-2275dx Front Panel: passo 5, immagine 2 di 2
    • Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
    • Set aside the top panel until your are ready to reassemble your laptop.
Conclusione
Erik Miller
Membro da: 04/22/14
2.123 Reputazione
4 Guide realizzate
Cal Poly, Team 11-51, Amido Spring 2014 Membro di Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 47
