Salta al contenuto principale
Disassembling HP Pavilion g7-2275dx Back Panel
Cosa ti serve
  1. Disassembling HP Pavilion g7-2275dx Back Panel, Battery: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Disassembling HP Pavilion g7-2275dx Back Panel: passo 2, immagine 1 di 1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. Disassembling HP Pavilion g7-2275dx Back Panel, Disassembling HP Pavilion g7-2275dx Back Panel: passo 3, immagine 1 di 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. Disassembling HP Pavilion g7-2275dx Back Panel: passo 4, immagine 1 di 2 Disassembling HP Pavilion g7-2275dx Back Panel: passo 4, immagine 2 di 2
    • Slide the back panel down and pull it up.
Conclusione
Altre 8 persone hanno completato questa guida.
John Sutton
Membro da: 04/24/14
1.566 Reputazione
8 Guide realizzate
Cal Poly, Team 11-51, Amido Spring 2014 Membro di Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,895
