Introduzione
You may need to replace or re-seat your heatsink if your computer constantly overheats and you don't hear any unnatural sounds from the fan. You will need some new thermal paste to apply.
Cosa ti serve
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
After you have removed the screw, the Solid State Drive should lift up.
Remove the highlighted rubber stoppers with a metal spudger as pictured. They should expose a screw that you will need to remove in a later step.
You should see eight screws. Each screw should have a corresponding number under it.
Unscrew each screw in with PH 1 Screw driver in numerical order. The screws will not come all the way out. Rotating the screw four to five times should make it loose enough to proceed. These are PM 2.0x11.0
Altre 7 persone hanno completato questa guida.
Un commento
These instructions worked perfectly for my HP Envy Touchsmart 15 J005EA.
I replaced with a none conductive arctic MX-4 without issue.
