Salta al contenuto principale
Disassembling HP Compaq NC6120 Laptop
Cosa ti serve
  1. Disassembling HP Compaq NC6120 Laptop, Disassembling HP Compaq NC6120 Laptop: passo 1, immagine 1 di 3 Disassembling HP Compaq NC6120 Laptop, Disassembling HP Compaq NC6120 Laptop: passo 1, immagine 2 di 3 Disassembling HP Compaq NC6120 Laptop, Disassembling HP Compaq NC6120 Laptop: passo 1, immagine 3 di 3
    • Flip laptop so the backside is facing upwards.
    • Pull the two plastic switches at the top of the backside of the computer outwards, and remove the battery.
  2. Disassembling HP Compaq NC6120 Laptop: passo 2, immagine 1 di 2 Disassembling HP Compaq NC6120 Laptop: passo 2, immagine 2 di 2
    • Remove all 13 screws from the back panel of the computer (includes the two torx screws under the battery and the two under the ram memory panel).
    • Remove the four screws at the hinge of the computer (also attaching the back panel to the rest of the computer).
    • All screws are 9.8mm 3.0 flatheads except for the two under the battery which are T9 torx.
  3. Disassembling HP Compaq NC6120 Laptop: passo 3, immagine 1 di 2 Disassembling HP Compaq NC6120 Laptop: passo 3, immagine 2 di 2
    • Open up the laptop so that the screen is facing towards you. Push the monitor back until it is flat, parallel to the keyboard.
  4. Disassembling HP Compaq NC6120 Laptop: passo 4, immagine 1 di 2 Disassembling HP Compaq NC6120 Laptop: passo 4, immagine 2 di 2
    • Using the iFixit opening tool, remove the plastic panel located between the keyboard and monitor. It should pop off easily with the spudger and can then be pulled away.
  5. Disassembling HP Compaq NC6120 Laptop: passo 5, immagine 1 di 2 Disassembling HP Compaq NC6120 Laptop: passo 5, immagine 2 di 2
    • Remove the white cable attached to the just-removed plastic panel from the motherboard.
  6. Disassembling HP Compaq NC6120 Laptop: passo 6, immagine 1 di 2 Disassembling HP Compaq NC6120 Laptop: passo 6, immagine 2 di 2
    • Flip the keyboard away from the monitor, rotating it so that the keys are face down on the mousepad. Remove the black cord at the bottom of the keyboard that connects it to the motherboard. The keyboard is now free and can be removed.
  7. Disassembling HP Compaq NC6120 Laptop: passo 7, immagine 1 di 3 Disassembling HP Compaq NC6120 Laptop: passo 7, immagine 2 di 3 Disassembling HP Compaq NC6120 Laptop: passo 7, immagine 3 di 3
    • Remove the two 9.8mm 3.0 flathead screws. There is one at each of the hinges.
  8. Disassembling HP Compaq NC6120 Laptop: passo 8, immagine 1 di 3 Disassembling HP Compaq NC6120 Laptop: passo 8, immagine 2 di 3 Disassembling HP Compaq NC6120 Laptop: passo 8, immagine 3 di 3
    • Unplug the black cable with rectangular white plastic head from the motherboard. It is located at the top left of the motherboard, directly below the left hinge.
  9. Disassembling HP Compaq NC6120 Laptop: passo 9, immagine 1 di 2 Disassembling HP Compaq NC6120 Laptop: passo 9, immagine 2 di 2
    • Pull the monitor directly upwards from where it lay. The two metal hinges should easily slide out of their holes and the monitor will be disconnected from the motherboard.
  10. Disassembling HP Compaq NC6120 Laptop: passo 10, immagine 1 di 3 Disassembling HP Compaq NC6120 Laptop: passo 10, immagine 2 di 3 Disassembling HP Compaq NC6120 Laptop: passo 10, immagine 3 di 3
    • Using the iFixit opening tool, pry the black plastic panel (with mousepad) off of the motherboard.
  11. Disassembling HP Compaq NC6120 Laptop: passo 11, immagine 1 di 3 Disassembling HP Compaq NC6120 Laptop: passo 11, immagine 2 di 3 Disassembling HP Compaq NC6120 Laptop: passo 11, immagine 3 di 3
    • Unplug the white cord connecting the mousepad to the motherboard from the motherboard, and pull off the entire plastic panel.
Conclusione
Altre 8 persone hanno completato questa guida.
Mateo Cuellar
Membro da: 04/08/15
601 Reputazione
4 Guide realizzate
Cal Poly, Team 17-4, Forte Spring 2015 Membro di Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Membri
6 Guide realizzate
Un commento
bravo j'ai bien reussi
merci
Zitouni Lebrieki - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 48
Tutti i Tempi: 9,174
