Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
A side panel is located on each side of the device. The right side panel, containing the button(s), controls the track being selected as well as the volume of the device. There are no prerequisites required for this guide.
  • A pry bar is necessary to remove the panel.
Parti
Nessuna parte specificata.
  1. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  2. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
Conclusione
After disassembling, the device and its components should look similar to that depicted in the cover image (top right of page).
Alexander
Membro da: 09/03/2012
101 Reputazione
9 Guide realizzate
Clemson, Team 15-3, Benson Spring 2012 Membro di Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 823
