Introduzione
Use this guide to remove the shell of the handset
Parti
Nessuna parte richiesta.
  1. Unplug the device before proceeding. Remove the phone cord from the phone jack from the base of the headset.
    • Unplug the device before proceeding.
    • Remove the phone cord from the phone jack from the base of the headset.
      • Use a plastic opening tool to remove the phone cord.
  2. Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
    • Remove the phone cord screw cap.
      • Unscrew the 7.5mm screw.
      • Remove the screw cap.
    • Remove the cord from the phone base.
  3. Remove the plastic cover with a Plastic Opening Tool by gently sliding the tool underneath the plastic and pry the cover off. Remove the plastic cover with a Plastic Opening Tool by gently sliding the tool underneath the plastic and pry the cover off.
    • Remove the plastic cover with a Plastic Opening Tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Remove the paper with a Plastic Opening Tool by gently sliding the tool underneath and prying the paper away from the phone.
    • Remove the paper with a Plastic Opening Tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Remove the rubber stopper with a Plastic Opening Tool by gently sliding the tool underneath and pry away from the phone. Remove the rubber stopper with a Plastic Opening Tool by gently sliding the tool underneath and pry away from the phone.
    • Remove the rubber stopper with a Plastic Opening Tool by gently sliding the tool underneath and pry away from the phone.
  7. Remove the two screws. Remove the 2 21mm screws by using a Philips #1 screwdriver.
    • Remove the two screws.
      • Remove the 2 21mm screws by using a Philips #1 screwdriver.
  8. Pull apart the handset by pulling the shell away from the other half of the phone.
    • Pull apart the handset by pulling the shell away from the other half of the phone.
  9. Remove 3 screws attaching the logic board to shell. Remove the 13mm screw with a Philips #1 screwdriver.
    • Remove 3 screws attaching the logic board to shell.
      • Remove the 13mm screw with a Philips #1 screwdriver.
      • Remove the 2 13mm screws with washers with a Philips #1 screwdriver.
  10. Slide out the phone jack from the shell by gently lifting up the phone jack. Slide out the phone jack from the shell by gently lifting up the phone jack.
    • Slide out the phone jack from the shell by gently lifting up the phone jack.
  11. Without removing the logic board completely, pivot the logic board out of shell.
    • Without removing the logic board completely, pivot the logic board out of shell.
Conclusione
Alles Rebel
Membro da: 20/09/2012
72 Reputazione
3 Guide realizzate
Cal Poly, Team 16-59, Forte Fall 2012 Membro di Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Membri
8 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,216
