Salta al contenuto principale
Disassembling Garmin Nuvi 1200 Logic Board
Cosa ti serve
  1. Disassembling Garmin Nuvi 1200 Logic Board, Logic Board: passo 1, immagine 1 di 1
    • Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
    • Once the tool is inserted it can slide around the entire device.
  2. Disassembling Garmin Nuvi 1200 Logic Board: passo 2, immagine 1 di 1
    • Remove four small T5 torx screws.
    • Be gentle, the screws are easily stripped.
  3. Disassembling Garmin Nuvi 1200 Logic Board: passo 3, immagine 1 di 2 Disassembling Garmin Nuvi 1200 Logic Board: passo 3, immagine 2 di 2
    • Lift cover off of unit.
    • Be careful not to lose small rubber piece on the bottom right corner.
  4. Disassembling Garmin Nuvi 1200 Logic Board: passo 4, immagine 1 di 1
    • Disconnect ribbon cable from logic board.
  5. Disassembling Garmin Nuvi 1200 Logic Board: passo 5, immagine 1 di 1
    • Remove two T5 torx screws holding down logic board.
    • Disconnect battery.
  6. Disassembling Garmin Nuvi 1200 Logic Board: passo 6, immagine 1 di 1
    • Gently lift the logic board out of the unit
    • Be careful not to damage the battery connector on the top of the unit.
Conclusione
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 5,234
