Salta al contenuto principale
Disassembling Ericsson CF 388 Sim Card
Cosa ti serve
  1. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: passo 1, immagine 1 di 3 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: passo 1, immagine 2 di 3 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: passo 1, immagine 3 di 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: passo 2, immagine 1 di 2 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: passo 2, immagine 2 di 2
    • After removing the battery, the SIM card is accessible. Locate the SIM card casing at the bottom right of the back of the front panel casing.
    • To remove the SIM card, using your index finger, carefully lift up and rotate the plastic casing.
    • Then, the SIM card easily slides out of the casing.
Conclusione
Cam Miller
Membro da: 03/09/12
1 Reputazione
1 Guida realizzata
Clemson, Team 1-1, Benson Spring 2012 Membro di Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 996
